Please Help
Username: Jessecapper
i need some info i have this amp:
Power MAX (2 Ohm) 500 Watts x 2
Power RMS (4 Ohm) 200 Watts x 2
Bridged Power 1000 Watts x 1
Tri-Mode Capable Yes
Remote Subwoofer Level Control
Input Level Adjustment
High Crossover
Low Pass Crossover (Variable) 40Hz - 150Hz
Bass Boost (Variable) 0 - +18dB
Inputs Speaker / Line Level
Signal to Noise Ratio 103 dB
THD @ RMS Watts 0.01%
Frequency Response 9Hz- 50kHz (+/- 3dB)
Channel Separation 90 dB
Damping Factor 125+
Dimensions 11"W x 2-1/2"H x 13-5/8"
And this sub:
Power handling: 500 watts RMS, 1000 Watts max
T Yoke: Industrial Chromed Hex bolt retained, Bumped and Vented
Double damper magnetic motor assembly
Cooling: Double Vented (T Yoke and Motor Side vents)
Voice Coils: 4 Layer Dual 4 Ohm High Temperature black Aluminum
Voice Coil Diameter: 2.2"
Nominal impedance: 4 ohms / per coil
DC resistance (Re): 3.2 ohms ea. coil
Frequency range: 20 Hz-1.1 kHz
Fs:32 Hz
QTS:.461
QES:.541
QMS:7.62
VAS:35L (1.23 cu. ft.)
SD:.0346M
SPL:89 dB 1W/1m
Xmax:16mm
Mounting Depth: 145 MM
Mounting Hole Dia.:246 MM
Net weight: 21lbs
AUDIOVIBRATIONS 1 Year Warranty
what is the safest, loudest way to hook this up... right now i have one side of sub to one channel of amp and other side of sub to the other channel IS THERE A BETTER WAY???
Username: Carguy
Post Number: 2285
Powering each voice coil on separate channel is never a good idea. All you need is a spike/surge in one of the channel and you will fry the sub.
I don't think your amp can handle 2ohms bridged. So wire the sub's voic coils in parallel for a 2ohms load and then attach it to one of the channel on the amp. According to your post, that'll give you 500w x 1. That's 100w extra compared to the way you have it set up.
