Will this hurt amp/speakers?
Username: Calaway
Austin, TX
Post Number: 27
I have 2-8 inch Fosgate HE2 dual voice coil(400watt RMS) subs. If I get a 2 channel amp with 300watt RMS at 2 ohms, will this hurt anything?
Username: Subfanatic
Walton, Ky
Post Number: 1847
what ezxactly is the question? also, are the subs DVC 4 ohm, or 2 ohm
Username: Calaway
Austin, TX
Post Number: 28
they are dual 4 ohm. The question is if I under power them by 100 RMS will it hurt anything.
Username: Solacedagony
New Jersey US
Post Number: 335
As long as the amp doesn't clip the subs won't get hurt.
Walton, Ky
Post Number: 1849
no it wont hurt as long as it didnt cluip as jake said
Username: Calaway
Austin, TX
Post Number: 29
How do I avoid clipping, by getting a good amp? Looking at RF amps.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 166
a good amp can still clip, you just gotta make sure the gains are set right and not maxed and the wireing is of good quality, the right size for your application and connected properly. and that your charging system is suffecient
Username: C_freh
I have a question, firstly let me start off my saying, i recently bought 2 brand new amplifiers and 4 new subwoofers. the Brand is CUSPID, i never heared of it before, but for the price i thought i would give it a try. Are these CUSPID things any good? please leave me some first or second hand accounts you had with this equipment.
PS- the amplifier is a 4-channel but is 2x80wt RMS, does that make any sense?
Username: C_freh
ohh yea its me chrissy again, the amplifiers are 1600 watts max power extreme 4 channel's and the subwoofers are 12" 600 watts max power
Username: Byrumjr
Post Number: 165
Chrissy
Max watts are for 1/10 of a second RMS watts are what you go by when looking for amps and subs. Do you have the RMS watts at 4ohms and 2 ohms for the amps. Are the subs single or dual voice coils and what ohms are they?
Username: C_freh
I do not have the RMS for both, but i know they are single voice coil. I think i have the answer i need, this stuff is supposed to be crap from what people are telling me
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 83
Yes, it is. Rule of thumb, you get what you pay for.
