Amplifier Voltage
Username: Iceflamekilla
Hartford, CT
Post Number: 7
I just bought an Alpine V12 2-channel amplifier that has a wattage of 80RMSx2 at 14.4 volts and 50RMSx2 at 12 volts. How do you adjust the voltage on the amp for maximum voltage?
Username: Steelheadgoof
Fairfield, California US
Post Number: 48
get a HO alternantor
Username: Jwbulger79
Florida
Post Number: 380
you cannot adjust the voltage on the amp. your car will put out about 12 volts at idle or when the engine is off. while running it will usually put out about 14 volts.
Hartford, CT
Post Number: 8
Thanks guys
Florida
Post Number: 383
you bet. wecome to the forum. check out these two links if you want to learn a sh1tload about car audio.
Basic Car Audio Electronics
Car Audio Central FAQ section
