Alright guys, i need some help!!!
Username: Importrapist
Savannah, GA U.S.A
Post Number: 137
Hey guys, i need to know what to line my car with. Im gonna strip my camaro down to nothing on the interior and line it with dynamat or something EVERYWHERE. The doors, under the carpet, the hatch, roof everything, but i need to know whats a good quality product, dynamat or what, what should i put in there. ONLY recommend something if U know for sure, not something you think will work. All help is appreciated.
Username: Carguy
Post Number: 2265
Dynamat WILL work very well as long as you do it properly as well as foam expanders for place where you can't reach.
Username: Jmloughrey
Farmington, CT
Post Number: 1148
also look into products such as Edead and brownbread....also ice/water barrier for roofing is a very good alternative that will cost about half the price...
check out this link:
http://www.sounddomain.com/memberpage/337124/6
Savannah, GA U.S.A
Post Number: 138
so the ice/water works very good Jeff. How does it keep out road noise, and little annoying sounds like rattling. Where would i look for edead, and how much is it???
Username: Taylor17
Kopperl, Texas
Post Number: 1308
There is also something call lizzardskin or something like that. Stuff is pretty cool, but it is pretty costly.
Savannah, GA U.S.A
Post Number: 145
Yeah, i wanna keep it down a little bit ha ha ha
