Choices, choices
J3
so would it be smarter to get two l5 inch l5s or two 12 inch l7s? and theoretically i could use the same amp on either of those systems correct?
and just a sidenote, what kind of amp would you have to use for a kicker solox 18incher, examples would be appreciated
Username: Subfanatic
Walton, Ky
Post Number: 1846
id go for the 12 inch l7's more surface area, but for the solox you can add more than one amp i believe, and i would run US amps
J3
wouldnt the 15s have more surface area? maybe i misunderstood you
Username: Invain
Michigan United States
Post Number: 1870
Yeah, not sure what sub's thinkin'. Two 15's will have more surface area than two 12's.
