Help with my set up...
I have 2 Pioneer TS-W126DVC, 2 Infinity Kappa 62.5I, and 1 Alpine MRV-F540. What would be the best way to hook this system up? Should I just hook the subs up to the amp, or parallel the subs and then bridge them in channels 3+4? Is that even possible? I'm new to car audio if you haven't noticed by now. Also, what type of sub enclosure would best suit the subs?
Username: Davids2004
Houston, TX USA
Post Number: 761
For those subs they appear to be 400 rms and I would defintely suggest a seperate amp for those subs and then run one kappa off channel 1-2 and one off 3-4. If you looking for alot of bass go ported if looking for bass and good quality then sealed.
