Speaker Gauge
Username: W00b
Post Number: 11
is there a way to tell a wire's gauge based on the wire itself? maybe counting the number of conductors or something lol.. i dunno, just tell me if there is
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 168
its sometimed written on the wire, you can pretty much guess and be close if you know the gauges or they make wire tools that you can use to measure the wire i think. conductors are different depending on who made the wire, so that won't work
Username: Carguy
Post Number: 2158
Your hardware store has a simple wire gauge tester. It's like a ruler with gauge holes.
