What type of capacitor?
Username: Perrydog
Flint, Michigan USA
Post Number: 84
i am looking into buyin a capacitor(s) i am gonna be runnin 2 kenwood 800watt amps what type of capacitor do u recremend and what farad or frade i forgot how to spell
Username: Bassfreak596
Post Number: 96
dont go for a capacitor.. go for an Alternator upgrade.
upgrade th magic 3 wires n the Alt.. that is it !
if u still want to go for a capacitor, remember its approx 1 Farad for 1000w
Username: Importrapist
Savannah, GA U.S.A
Post Number: 88
I have to agree with morphine, change that alt, but if you want a cap...like morp said its 1 fard per 1000watts, and i would go with Stinger caps... $hit i have one just for looks. I upgraded my alt and a yellowtop.
Username: Carguy
Post Number: 2132
A capacitor will help only after an alternator upgrade.
If however, you use self control with the volume level, then capacitor will help smooth out some voltage rails.
HOW DO YOU BRIDGE A PUNCH 40 AMP TO ONE 4 OHM PUNCH 15" WOOFER?
