JL 1000/1 on X.X.X.????????
ive been hearing that the jl 1000/1 is underrated is that true??? well even if its not will the 1000/1 be a good choice to supply this sub? will this give the X.X.X. its full potential?
Username: Taylor17
Kopperl, Texas
Post Number: 1175
Yep, if the box is built right, the x.x.x only needs around 1000 rms to reach full excursion. That amp will work fine.
where can you find the jl audio slash series amps for a decent price?
Username: Mr_kebo
Albertville, Al USA
Post Number: 157
Username: Taylor17
Kopperl, Texas
Post Number: 1178
www.sonicelectronix.com I believe has a few JL amp's, and www.wooferetc.com has some as well.
Username: 1ohm
Dunnellon, Florida U.S.A
I was told by Mark at RE today that the X.X.X .12 will need at least 1200 watts to reach full exusion,He talked me into buying the X.X.X. over the SX becouse I am running an Orion 275g4 and want to do a sealed enclosure.never the less If your set on running a class D amp look for a Brutus BX2005D 2000watts. It is cheaper and it matches your X.X.X.'S spec's much better.(1600 RMS 2500 MAX) Don't be fooled..Hifonics is a good amp!I'm not knockin JL but" get your watts man!!!!your sub will thank you for it
Username: Fordpwr
Los angeles, CA Usa
Post Number: 147
NO Way!!!! do not go hifonics!!! That amp will NEVER put out 1600 w rms. Thats why they're so fu(ken cheap...
Username: 1ohm
If the BX2005D won't put out that kind of watts then I stand corrected.Just trying to give more options.I have never owned any of the new Hifonics but I have used the old school ones.VERY POWERFUL and CLEAN...I have just been informed that that JL amp will do 1200 watts...The kicker kx1200.1 is not a bad amp I'm told that it will do 1400 watts at 1 ohm and it is cheaper as well.I don't think that the 1200 watts will give it full potential in a sealed box.But if your after a ported box it may be the ticket.
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 440
yeh but the hifonics will put out around 1350 so it'll put out the power needed.
Username: Lilgator
Louisville, Ky USA
I called RE with the same question about using a Orion 1200D with a X.X.X. 12" and they told me I would get more output of of two 12" SE's. So I ordered 2 SE's
