SIlverado Ext Cab..
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 38
Does anyone know how to get the back seat to fold down? And is it better to put a sub behind the seat, or under it?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 39
Also, whats a good sub with a shallow mounting depth? I'm looking for a 10" on the cheaper side. The only decent ones I can find are JL 10w0, 10w1 or Diamond Audio TM310D2. Only want one sub, at like 250 watts rms, but I would still like a little bump.
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 773
Check out the Koda 10 here:
http://www.adireaudio.com/
It only has a 4.75" mounting depth, but unlike the w0's I think you need to allow for about another 3/4" so the voice coil can vent properly. Its probably a much better sub for your application (handles 300 watts w/ 18mm Xmax), but costs a lil more than twice what a 10w0 would go for as well.
-Fishy
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 416
yeh but the price is well worthed because the koda would produce way more spl than the w0.
Username: Subfanatic
Walton, Ky
Post Number: 1720
i love how everyone hates on the w0
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 43
Is better to go ported or sealed? SQ being my main goal. Thanks for your help.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 44
Does anyone know where I can pick up a Koda10 for less than $150 or should I just get the 10W0?
Username: Cdj
Southern Ohio
Post Number: 17
You should also put Image Dynamics on your list if you primarily want SQ. They have some umph and can bought from an authorized dealer for less than $150 shipped.
http://www.imagedynamicsusa.com/website/tech/data_sheet_idq10d4v2.html
http://www.imagedynamicsusa.com/website/tech/ID10D4V3.pdf
http://www.cardomain.com/shoplist~b~Image+Dynamics~t~Subwoofers
