Is 1 1000/1 strong enough for 2 12w7
Travislle
Is 1000/1 strong enought for 2 12w7 or should i just go with 2 10w7's. What would my sq and spl diffences be. Also, what would be a good guesstimate on my db for the 10w7 set up.Thanx
Username: Subfanatic
Walton, Ky
Post Number: 1656
i would go with the 10's but thats me, lol, but if you go with the 12 w7's there is always that possibilty of in the future buying another 1000/1 and have an amazing system
Username: Jeremyc
OK in less t... South Korea
Post Number: 603
Travis 1 JL 1000/1 will be louder on 2 12s than it will on 2 10s. In other words it will work fine, and yes you can always add a second amp later.
Username: La2lvtom
Your 2 12W7's will be underpowered but adding a second 1000/1 will definately make you happy, if you only plan on 1 amp do yourself a favor and go with 2 10W7's. I was the USACi region 10 points champion 2 years ago. I was running 1 13W7 off of 1 Kicker XS 100 (birth certificate 1304 watts at 1 ohm) and in a downfire ported box was doing a 149.3 on the floorboard open vehicle, 145.2 on the dash sealed and a 159.8 port wars and the sound quality was excellent. You will be very happy with whatever size W7 you decide to go with.
Username: Jeremyc
Post Number: 608
I agree any size w7 will sound nice. But is there really such a thing as underpowering. It doesn't matter how many watts your amp puts out, clipping is clipping and it will destroy any speaker. Keep in mind the only time an amp puts out its full rms power is at full volume or right below clipping. So if underpowering a speaker was really that big of a deal (minus the clipping) then why doesn't every speker blow after a little use? The point is, he can push 2 12W7s with a 1000/1 just fine and still get louder than the 2 10s.
Username: Suleman36
Post Number: 423
Anyone know the output potential of 1 10W7 in a custom H.O. wedge box runnin off a 500/1 vs. 2 10W7 in a differant box like sealed or ported running of a 1000/1 cause the H.O. is one of a kind box and its huge for one sub. Or maybe vs. 1 12w7 in a sealed box? I know it will be very efficiant in this box but not sure how they compare to the others i mentioned.
