Woo woo
i was looking at zapco and they are very expensive. are they good for the price. or i could find something else for the two subs i got ATW12X they are rated for 3000 max and 2000rms each. what size of amp do i need .1000w.etc.
very lost at this .( $1500.00 is a bit much for one amp , i am not in any comp.just want something very loud whith out bracking the bank.)
help pls.
Username: Nitescort
Post Number: 24
you buy a average sub and then want to power it with a great amp? get a Audiobahn to power it. might as well have junk powering junk. sorry for sounding so harsh but I just hate Audioblah.
Username: Rob315
Cuse, NY U.S.
Post Number: 388
audiobahn isnt junk...pursae...they arent the greatest by far...but they do get loud...they dont sound to great though...and i wouldnt power that audiobahn with that zapco amp unless you were going to be upgrading your sub in the future.
THEGAME22193
no problems i can returned them . give me some thing good .what about orion H212.4SPLHCCA 2000rms,2500max are they also crap if it is give something good with the same wattage.
thanks for the responce. verry helpfull
audiobahn going back.
Username: Carguy
Post Number: 2068
Audiobahn is not as bad as some people make them out to be. I've personally tested them. They are good for people with low budget. Unlike Sony/Pyramid/Lanzar/Pyle, it delivers.
For better subs, look at RE X.X.X., JL, and Orion. If you have the space, then try 15".
Username: Thegame22193
thank for the info. 12 is what i want . like to have a tighter bass . don't care to much for 15's
any model on the 12 i can use with 2000w rms
the orion H2 sounds good. any thing better . i will say about $1300.00 for two subs. i am aready spending alot on two zapco amps so money is abit limited for the subs. zapco C2K-9.OXD and C2K-2.5X.
Username: Carguy
Post Number: 2071
With the Zapco's C2K series amp, C2K 6 and 9 are the only 2 worth purchasing.
Take a look at JL's 12" subs too.
any particular model i need to look for . sorry for all the rookie question but i want this to be almost perfect.
Username: Carguy
Post Number: 2072
Try JL Audio 10W7-3, JL 12W7 12".
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 748
I'm not sure that C2K-9 matches well with any 3 ohm subs. Its got some pretty strange power specs. It'd either produce 2000 watts into one w7 bridged or 2x400 into a pair. To get a more acceptable level of power you'd probably have to bridge the thing into a couple of series wired w7's which according to JL is something that should "be avoided at all costs".
from here:
http://www.jlaudio.com/tutorials/wiring/index.html
I guess 2 10w7's at 400 watts each or one 13w7 at 2000 watts might not be too shabby, but I think if your going JL w7's your better off with a JL amp(1000/1).
-Fishy
hey guys what you think of this set up ...
the zapco C2K-9.OXD and two orion H2. 2000 rms each.
the zapco C2K-9.OXD and two orion H2. 2000 rms each. or i am still far from getting the subs right.
Username: Carguy
Post Number: 2082
Zapco's C2K 9 is 2200w rms of power. Are you sure you will be able to stand that much sound pressure? You will either go deaf or the car will break down.
Anyhow, you will be very impressed with those combo.
Post Number: 8
THANKS MAN . that was the answer i was looking for . so i am going in the right direction ... perfect.
