A little help please please!
Username: Madhops
Los Angeles, CA USA
Post Number: 28
Ok here's the problem. My sister has a 92 Galant and when you wanna put aftermarket speakers, you can't just connect them cause it has some weird wire. Is there anyway of connecting them without buying the adaptors?
Also, she has a detachable face stereo and I was wondering how to take it off. Her fader and balance are connected all wrong, and I wanna fix it for her. If anyone can help me it would be greatly appreciated
Username: Invain
Michigan United States
Post Number: 1805
Only other thing you could do besides running new wires is to figure out which wire is positive and which is negative. Then just cut the adaptor end off and strip the ends of the wires.
Username: Fishy
TamaracFt.Laud, FL USA
Post Number: 703
You can figure out the polarity using a a small battery and the factory speaker. Just wire the battery to the speak. If the cone moves out then whichever terminal you connected the positive side of the battery to is positive. If the cone moves in its just the opposite.
Depending on the factory connector you may be able to build your own wiring harness with some male and female blade connectors(quick disconnects) and avoid cutting the factory stuff.
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5 F011%5F003%5F004%5F000&product%5Fid=64%2D3134
The one on the left is the guy.
-Fishy
Username: Madhops
Los Angeles, CA USA
Post Number: 29
Thanks, what about pulling the stereo out? How do I do that? It's a detachable face stereo.
