Buying 6x9's and 4" speakers.. Need help
slm
I am looking at buying 6x9's; either:
- Sony XSV6930A or
- Pioneer TS-G950M
Which has the highest quality?
Also, I am looking at buying 4" speakers - Pioneer. Any negative points on Sony speakers / Pioneer speakers? What should I look out for?
Username: Jwbulger79
Florida
Post Number: 293
slm, sony makes poorly built car audio products. stay away from them.
6x9's in general will have poorer sound quality than a round speaker. if you can fit them, look at getting 6.5's instead.
slm
They sounded alright in the store. Im not looking for the best sound, just ok sound for a good price. I want to get either one or the other. Whick is better?
slm
and what is wrong with sony? do they have poor sq or will they just break easily?
Florida
Post Number: 298
they may sound ok to you, but they are poorly built and have a bad reputation for messing up.
https://www.ecoustics.com/electronics/forum/car-audio/8567.html
Username: Dkchillin
Vermont
slm, I can speak from experiance on this. When I got my first car back in '98 I put in a sony head unit and sony 4x6's because 1)my car had no radio when I bought it 2)I didn't have much cash to spend and 3)I didn't know any better. A year later I was kicking myslef because the HU no longer played CD's and the right front speaker had blown out. I upgraded to a Pioneer HU and Pioneer 4x6's and the difference was amazing. I still have the deck and the speakers and I plan on taking them out and transplanting at least the speakers when I get my new ride this summer. It's worth a few extra bucks for much better quality. Hope that helps.
slm
i still like the 6x9's because they fit in my car. Pioneer ts-g950m is good?
wait... will 6.5's fit in a hole made for 6x9's?
