US Acoustics USA 2150?
Username: Billie26
Post Number: 16
Hi all. I bought a US Acoustics USA2150 150wx2 off ebay for $60, but I thought I won a USX2150 (a misread, since I didn't know the USA version existed).
Can anyone tell me if this is a good amp or not, and what its retail value is? I can't find it off google or this site. It must be old. Thanks.
abe
$240 at crutchfield
no pre-amp outputs
this sounds like a good amp...
i think this is the specs on the amp
OUTPUT POWER
Per channel @ 4 Ohms
@ 12.9v input 150Wx2CH
Per channel @ 2 Ohms
@ 12.9v input 225Wx2CH
Bridged Mono @ 4 Ohms
@ 12.9v input 450Wx1CH
FREQUENCY RESPONSE
10Hz-30Khz, -0.5dB
TOTAL HARMONIC DISTORTION Less Then 0.01%
INPUT SENSITIVITY, HIGH LEVEL 220mV-17.6V
INPUT SENSITIVITY, LOW LEVEL 110mV-8.8V
DAMPING FACTOR 150
PROTECTION
Reverse Polarity Yes
Thermal Yes
Short Circuit Yes
D.C. Yes
FUSE RATING 35A
SIZE inches (mm) Length 14.6 (370)
Width 9.6 (244)
Height 2.5 (63.5)
Username: Billie26
Post Number: 17
Thanks Abe. I couldn't find it anywhere on crutchfield, though. I actually couldn't find any us acoustics products.
Username: Abew330
Camarillo, Ca Usa
sorry i meant to put was $240 at crutchfield a few years ago
