New member Username: ThenoosePost Number: 2 Registered: Mar-05 | spl,sq etc etc which sub would you rather have in your car |
Silver Member Username: Rob315Cuse, NY U.S. Post Number: 291 Registered: Jan-05 | if ya end up choosing type r's i have 3 ill sell ya for a good price. brand new in box. email me at rtc0420@yahoo.com |
New member Username: ThenoosePost Number: 3 Registered: Mar-05 | plz someone answer lol i have to know by tommorrow night |
Silver Member Username: Nnnnick_bNc Usa Post Number: 224 Registered: Jan-05 | I believe the infinity will win in the sq department, but the alpine isnt far behind. The alpine will win in spl. I would personaly like the alpine type r. But if u are looking for pure sq go for the infinity. |
New member Username: ThenoosePost Number: 4 Registered: Mar-05 | thanks i have had the alpine r 12 and i remember it being good but all my compnents are infinity and i heard the sub was really good but i want the best spl i can get out of the two subs so i guess u answered my question |
Silver Member Username: Jwbulger79Florida Post Number: 222 Registered: Nov-04 | yeah, i agree. also check out Image Dynamics subs. great SQ. |
New member Username: ThenoosePost Number: 5 Registered: Mar-05 | image dynamic subs are expensive for wat they are i killed a image dynamic sub with my last setup had a kicker l7 those things pound but no sq and everyone keeps telling me the infinity kappa perfect 12.1d is a awesome sub im sooo confused and out of those 2 i just cant make a decision by the way im runnint a a8000t amp i have a pioneer face not the new color one but the one right underneath that and all my spekaers are infinity kappas and being run off a 5 channel mtx |
Silver Member Username: Nnnnick_bNc Usa Post Number: 226 Registered: Jan-05 | What about something from acendant, such as a 12 or 15 inch atlas? I think its 140 for the 12 and 180 for the 15, are u planning on getting one or two? |
Silver Member Username: Jwbulger79Florida Post Number: 229 Registered: Nov-04 | ive got an atlas 12. it was $145 and only $15 shipping. Chad, the owner, is a great guy to deal with. give him a call and he'll let you know what's up. nick, i went back and forth for a while trying to decide what to get, a type-r vs a perfect. finally i decided to shell out a couple more $ for an atlas. it uses the same motor as the RE x.x.x. and the adire brahma. it also has a very unique feature - a second voice coil that is used to adjust Qts, basically it tweaks the bass. i bought a $3 part that i mounted on my dash that allows me to "tweak" the bass on the fly. it's sweet, and very unique. give chad a call and ask him about the adjustable "Q's" and how you can mount a potentiometer on the dash to get the exact sound that you prefer from your sub. |
New member Username: ThenoosePost Number: 6 Registered: Mar-05 | IM getting 1 cause i have a ranger and it goes behind my seat but im tryint to decide on those 2 cause thos eare the only ones id be interested in but do u really think alpine beats infinity on spl??? |
Gold Member Username: SubfanaticWalton, Ky Post Number: 1024 Registered: Dec-04 | how are the atlas's in the spl and sq department, compare it to somen lol...my friend might consider one |
Silver Member Username: Nnnnick_bNc Usa Post Number: 228 Registered: Jan-05 | I've heard about that. I wish my tempests had that : ( |
Silver Member Username: Nnnnick_bNc Usa Post Number: 230 Registered: Jan-05 | Very good sound quality. As for spl, the atlas has 18mm of one way xmax. Consider that an infinity 12.1d has around 12mm and a type r will be around 13-14mm. A XX.X has 32mm. |
Silver Member Username: Jwbulger79Florida Post Number: 231 Registered: Nov-04 | sub, it's not installed yet, so i cant tell you how it sounds ![]() in the last pic on this page ( http://www.cardomain.com/memberpage/803011 )you can see part of the box construction. that's a storage box, it will be identical on the other side, and the sub box and amp rack will go across the middle. hopefully i'll be done in the next couple weeks. |
Silver Member Username: Nnnnick_bNc Usa Post Number: 231 Registered: Jan-05 | Nice install so far. I like the work you did on the doors. |
jimbo911 Unregistered guest | J.W....what would the number be to get ahold of Chad. Im thinking of picking up an avalanche 15 or 18 but im not sure. whats the sq like? spl? how many watts to get it moving nicely? |
Silver Member Username: Jwbulger79Florida Post Number: 235 Registered: Nov-04 | (815) 477-2423. it's a real small company. i've called a few times and either chad answers or some dude name dale, but if you ask him a question, he just gives chad the phone ![]() thanks nick. not bad for my first install huh? the back will be sweet when i get done. i'm gonna paint it all with some tan colored spray on bed liner type stuff. |
Gold Member Username: Jonathan_fGA USA Post Number: 3489 Registered: May-04 | In the price range, I'm a fan of Image Dynamics IDQs. I guess overall next I'd take the Type R, pure SQ I'd still go ID, then Infinity, then the Alpine. |
Silver Member Username: Jwbulger79Florida Post Number: 236 Registered: Nov-04 | the first time i called i was considering getting an adire shiva. i straight up asked chad how the atlas stacked up against it. he was very respectful of adire audio, but was confident he made a superior product. just ask him. he's not a salesman and he's not some half-a## tech support dude. he's the inventor of the subs, and a straight up fellow. |
Silver Member Username: Jwbulger79Florida Post Number: 238 Registered: Nov-04 | jonathan, what do you think of ascendant audio? |
Silver Member Username: Rob315Cuse, NY U.S. Post Number: 299 Registered: Jan-05 | for some reason that makes me want to give him my money as well. it seems like a more than legit company with descent people working there. kind of gives me that feeling right after you take a shot of 151...all warm inside. how would 2 avalanche 15 sound?..im also considering a single x.x.x. 18 or 2 sounsplinter 15" sp l.series or whatever it is. |
Gold Member Username: Jonathan_fGA USA Post Number: 3492 Registered: May-04 | Great subs, I like Adire and it's brother/sister companies, all of them (RE, Adire, Ascendant)have very good, down to earth people backing them up. They will readily admit their products benefits and if other products outperform them in some area or another, and that's what makes a company what it is, and shows your commitment to the hobby instead of profit margins. When you're willing to acknowledge that another product may outperform yours in some way, it helps you make a superior product by realizing any shortcomings or areas of improvement. You can't go wrong with the Avalanche, either, I just overlooked it on my last post. |
Silver Member Username: Rob315Cuse, NY U.S. Post Number: 300 Registered: Jan-05 | what sub could they be compared to in spl?...sq? |
Just Deep Unregistered guest | Image Dynamics No.1 in SQ. After that my votes in order are to Infinity Perfects and Alpine Type R's |
