Amp for 12w7
Username: Adampit
Post Number: 24
i am aquiring a 12W7 in HO box and now need to get an amp. I can not afford the JL 1000/1 amp so i was looking on ebay at Hifonic amps i was wondering which of these would power the 12w7 nicely. I have heard the w7 only takes 3 ohm but none of these amps say 3 ohm so im asking you guys, or you guys can suggest me other amps for around 300 bucks..
HIFONICS BX1605D
1600x1 @ 1 Ohm
1100x1 @ 2 Ohm
HIFONICS Brutus BX1500D
500x1 @ 4 Ohm
1000x1 @ 2 Ohm
1500x1 @ 1 Ohm
HIFONICS Brutus BX1205D
900x1 @ 2 Ohm
1200x1 @ 1 Ohm
fatjoee
get one of those 500/1 jl amps.. that will push the w7.. you get 3 ohms on how you wire everything..
fatjoee
fatjoee
the 500/1 jl amp should only be around 350
