Power needs
Ok so i was told i need to run 4gauge wire from the alt to batt from block to batt and ground to batt but there is a reg on the line from the alt so what should i do, just by pass it or run the wire there? every thing else is as good as done just the reg is got me confuse any help is welcome
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7493
you want solid current flow throughout the circuit, so find the main positive line from alt to battery, and upgrade it.
if it goes through the voltage regulator at that point, replace everything to and from the regulator, which should have a bolt-connector attaching cable for power in and out
