Help! powering an Alpine 9813
Username: Fdafire
I have an 9813 that I had installed in the glove box of my 1966 Lemans so not to mess with the dash. I also had 4" kappa's up front and Kenwood KFC-XR901 6x9 in the rear. They did a great job, and it sound pretty good. I even get some good bass from the rear. My question is...what differece is it going to make that they did not run the wire kit to the battery for the V drive amp. Should I have it done. I don't mind if it really is going to make a difference in sound. Oh! i am not using any other amp or anything, just the HU. Thanks
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1580
it may make for cleaner sound with less distortion due to clipping but primarily, what you'll gain is less chance of burning up the wiring from current draw.
a single 10AWG line to the battery's positive terminal with an inline fuse for ~110A draw is sufficient for that unit.
good unit, nice car.
I used to mess with a few 68 and 70 GTOs and Judges a friend had.
Username: Glasswolf
Post Number: 1581
correction, 110 watts, not amps.
sorry, I wasn't thinking.
that's about a 10-15A fuse. should be plenty.
