Similar to Kappa components ?????
No dealer or store
I hear that the kappa components are pretty good components but a little bright. There is no dealer in the area for me to listen to them. Does JL, Apine, Fosgate, Eclipse, or MTX make a comparably bright set I can listen to too see how bright they are.
Username: Jwbulger79
Florida
Post Number: 226
check out the CDT component set on www.thezeb.com for $150.
they are some badass comps that got rejected from cdt b/c the color of the speaker was not quite right or something like that, but soundwise they are fine. they have a soft dome tweeter, so they wont be quite as bright as the kappas.
Florida
Post Number: 227
here's the link:
http://www.thezeb.com/p-CDT-Audio-CL-61A-6-1-2-inch-Component-System-101083.htm
