Spl (1w/1m)
Username: Rob_brown
Post Number: 162
What does this mean? for instance 89.3 or 92 spl (1w/1m)? thanks
Username: Cory
Post Number: 140
it means if i were to be standing 1 meter away from the speaker that the spl will be at 89.3 or 92 as you stated
Username: Cory
Post Number: 141
at my ears
so if i were to have a speaker with 92db at 1 mete, and a 130watt amplifier you could hit 113DB
watts/db
1=92
2=95
4=98
8=102
16=105
32=108
64=111
128=114
Username: Invain
Michigan United States
Post Number: 1661
NO. You cannot just take the effeciency of the sub and plug it into a formula.
Username: Cory
Post Number: 144
that is true because it does not take into consideration of a the box and the enviroment but will give you an idea
Username: Invain
Post Number: 1662
Roughly. Spl does depend on other things as well. You also have to take into consideration the speaker design.
The difference in the xmax is due to the difference in overall length of the voice coil. Xmax=voice coil length minus the gap height. The difference in efficiency is due to a different number of windings in the gap. The current passing through the coil generates a magnetic field which is distributed along its length. On a shorter voice coil, more of the generated field is in the magnetic gap producing a slightly stronger motor but with a shorter stroke. You can make a speaker really efficient by designing the voice coil to fit entirely in the magnetic gap. This would likely yield a sensitivity of 104 or so. This speaker may work very well if powered by a low powered amplifier because of the high efficiency but would not be able to produce high SPL at low frequencies because it would have a very small xmax.
You also have to consider the frequency played, as well as the xmax of the speaker. Efficiency alone should never be used to find the db's a sub will hit.
Username: Cory
Post Number: 145
ok, I see what you mean by high sencitivity put with high x-max. So in other words when the cone is at high excursion it leaves the magnet gap witch reduces the sencitivity b/c its not as close to were it once was in the normal position in the magnet gap.
please correct me if im wrong. I did not know that. I geuss it is true you do learn somthing every day
Username: Invain
Post Number: 1664
Not really, it just doesn't have as much xmax - excursion. In order to produce lower nots a sub needs to be able to go through more excursion.
"So in other words when the cone is at high excursion it leaves the magnet gap"
I don't believe that's possible. If the voice coil left the magnet gap the sub would no longer have any control over the cone.
Username: Cory
Post Number: 148
ok,true ture thanks for the info on the matter. never looked at it like that before.
Username: Invain
Post Number: 1668
No problem. I hope I didn't come off as rude, lol. When I read my responses a second time it sorta sounded that way. I just wanted to correct you.
Username: Cory
Post Number: 150
no offence taken, we all have to be corrected some time
Username: Invain
Post Number: 1671
Good, lol.
Username: Jonathan_f
GA USA
Post Number: 3468
Not a good basis to go by really. Once you put a couple hundred watts on a subwoofer, results change. The sensitivity of a subwoofer (or speaker for that matter) does not relate to it's efficiency, which would be the power in compared to the power out, and it won't dictate how loud a subwoofer is capable of getting. Many manufacturers rate sensitivity differently, you have to consider the type of enclosure they used, whether free air, sealed, etc. and also the location they put it in when they measured it. An example is the Infinity Kappa Perfect subwoofer, the 96db figure may look good, but they measured that with 2.83V instead of the typical 1W/1M sensitivity, and also put that subwoofer in a car for the measurement and not anechoic, which boosts the sensitivity by a huge amount. Independant tests have measured that sub in the 80s with normal methods of testing at 1W/1M. You also have to consider the frequency they measured at and other factors. High sensitivity is usually accomplished with lightweight materials, such as a light cone, foam surrounds, and looser suspension, also motor strength plays a big part of it. Lightweight can be bad or good depending on what you're looking at, too light can result in a lack of damping of the driver, degrading SQ. Subwoofers are capable of moving out of the magnetic gap with enough power, but of course it usually isn't recommended. If you have the suspension to handle it, you can stay somewhat linear doing so, but you do lose motor strength and a lot of control, like Joe stated. This is typically done in sealed boxes with high power, especially at the resonant frequency of the system.
