Like
Escalade set up
Username: Gakel05
Florida Usa
Post Number: 9
i have 2 jl 12w7s 2 1000/1 amps and a custom box for both woofers w/ a slot port, the woofers share the same air space, no divider, i will be transferring this to an Escalade, would the ported box that i have sound best or should i go sealed, or should i go ported w/ a box and divider? i want good deep bass and good sq...any suggestions
Username: James1115
Wilton, Ct
Post Number: 1873
stay with the set-up you have now.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 433
i would keep the equipment you have now...just like james said
also, i would go w/ a vented box w/ separate air-space for each sub. if the vented box is built well, then the SQ should remain good.
whats the difference between vented and slot ports?
Username: James1115
Wilton, Ct
Post Number: 1885
nothing
Facebook
Shop Related Deals
Directory
