JBL power series
Username: Bobo123
Post Number: 46
I can get a jbl 180.2 power series used for $100, is this a good deal to run my kappa components off of at 90rmsX2 at 4 ohms?
Username: Carguy
Post Number: 1894
If you want a better amp for around the same price, then try PPI PC/PCX/Art series amps.
Username: Bobo123
Post Number: 47
if I cant find one of those for $100 will the jbl be Okay for that price?
Username: Bobo123
Post Number: 48
I found a ppi pc425 for $125 used. Is this a good deal? I will bridge it at 4 ohms to produce 100 rms per channel
Username: Carguy
Post Number: 1900
That is a good deal. PC425 is made in USA. High quality.
