What could be the problem
Username: S_law
last year after i blew my subs and had new ones sent to me they didn't work for some reason my amp came on and everything so i sent my amp in and got it checked out yesterday i took the subs in the house and checked them on my home stereo they worked fine i put them back in the box and hooked them up in my car they worked for about 15 minutes then cut out i checked all the fuses and my wiring what else could be wrong
Username: S_law
i guess no one can help me
Username: Invain
Michigan United States
Post Number: 1431
Is your amp overheating?
Username: S_law
no the subs aren't working today it used to overheat alot tho
Username: Invain
Post Number: 1433
Does the amp power up anymore at all?
Username: S_law
Post Number: 7
yeah man the amp comes on but i'm not getting any noise out of the subs i noticed that when i hooked them up in the house one set of + - posts on each sub didn't work
Username: Invain
Post Number: 1434
You probably blew a voice coil.
Username: S_law
Post Number: 8
so i should probably take my subs out and rewire them
Username: S_law
Post Number: 9
or is there anyway i can fix that cuz i really don't wanna have to eat these subs i haven't even used them but like once
Username: S_law
Post Number: 10
u still there
Username: Invain
Post Number: 1435
I'm not totally sure if it is a blown vc, but thats what it sounds like. Try hooking just one voice coil up to the amp once and try it. Don't play it for long, just see if it works.
Username: S_law
Post Number: 11
but if the voice coil was blown would the sub not produce any sound at all
