Adding a second sub???
Username: Sublime420
Ca Us
Post Number: 121
right now i have a RF 12" punch stage-2 sub(single 4ohm coil), powered by a RF p3001 amp. the amp does 150w RMS @ 4ohms, and 300w RMS @2ohms. so the question is, if i get another punch stage-2, and run it off the same amp as the other one (so each gets 150w RMS), will it make a very big difference?
Username: Alpineuser
Post Number: 15
yea i think u would actually lose spl and sq. I belive the RFp2 is 200 rms right?
Ca Us
Post Number: 123
yeah. it is. but right now i have one and its only getting 150watts. so if i have two, and they get 150watts each, will it be much louder than having just the one getting 150watts???
Ca Us
Post Number: 124
actually, the amp is rated at 150w RMS @ 4ohms, but the birth sheet says that they measured my amp, and it did 210watts RMS @ 4ohms. thats pretty cool.
Ca Us
Post Number: 126
anyone???
Username: James1115
Wilton, Ct
Post Number: 1666
well typically when you add a sub and double the power you gain 3db's which is a good amount. you will deff notice a difference.
Username: James1115
Wilton, Ct
Post Number: 1667
