Sub Box Question
DUMTEF
I have a box with 2 12" kicker comp vr's in it, its about 5.4cubic foot in total, it has one port at the moment which is in the front between the 2 subs, my question is would i be ok to add another port out the back of the box (i also beleive that the existing port is to small its 2.5")
thanks adam
Username: Invain
Michigan United States
Post Number: 1403
Adding another port would totally change the tune of the box.
DUMTEF
yes i know but i beleive the port that i currently have is to small for 2 12" subs, and there is no room for another port on the front of the box thats why im wondering if it would be ok to have a port on the front and a port on the back
Username: Invain
Post Number: 1406
It should be, I'm not totally sure.
