Boss amp
Username: Chinaman_87
Houston, Tx Usa
Post Number: 16
hey would a bossc650 amp
100x4 rms at 4 ohms
250 x 4 max at 2 ohms
be able to power some infinity kappa's good?
will it over power it?
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=12497
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14268
i heard infinity has one of the best speakers but would this sound nice with 2 12 jlw3v2's?
Username: Xxkmfdmxx
St. Petersburg, FL USA
Post Number: 407
Might be alright. The only Boss amps I can really reccomend though are the IQ series. The c650 wont overpower them, It MAY power them nicely if its not overrated.
Username: Marley289
Post Number: 124
not saying that you shouldnt get the amp but if your going to buy nice subs like the kappa's, why not buy a nicer amp. ive heard that boss is bad quality. maybe go with MTX, thats what kind of amp i have and im not dissapointed
Houston, Tx Usa
Post Number: 19
thanks for the help. my reasoning was why not give it a try for the price ill look into the mtx's thanks again.
