Should my car be able to handle it?
Username: Tdbdrummer
Post Number: 113
If I get the JBL GTO 1201.1 amp, and run my new subs to it, should my car's electrical system be able to take it? It's and '02 Cougar.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 50
not sure how many watts that amp puts out, but just do this
RMS wattage/12 volts = amps your'll be pulling
if your pulling less amps then your alternator is rated at, then it'll be ok.
Username: Carguy
Post Number: 1712
TB, the answer is NO. Stock alternators are 65A - 75A the most. Your electrial system uses bulk of that piece, leaving you very little for amps.
Post Number: 116
SO, what do I do? I want to run my subs :-(
Username: Goon
Post Number: 25
buy a h/o alternator. i have to do the same thing as well....
goon
Post Number: 118
Well, is there any other option, like a lower powered amp? I have friends who have decent amps, and they didn't have to have new alternators.
Post Number: 119
How about a capacitor?
Post Number: 120
If not, where can I find these alternators online? Website?
Username: Invain
Michigan United States
Post Number: 1342
www.mralternator.com
www.4alterstart.com
www.motorcityreman.com
Post Number: 121
Are they universal?
Post Number: 122
Itty bitty problem, would Ford = Mercury?
Post Number: 123
I can't find one for my Cougar.
Post Number: 126
What do they mean by a remanufactured alternator? Refurbished?
Username: Carguy
Post Number: 1715
Most all alternators are, or else you'd be paying $500 or more.
Just call those places posted above, and they will gladly help you out. You need to get one for your model and no guessing.
jimbo911
i have 1600 TRUE rms watts. and i dont even have a dimming problem. using all stock electrical system.
Post Number: 127
See, this is where I get mixed signals, friends of mine have good stuff, and they don't have new alternators. Thnere Jimbo just said he has stock stuff, but with 1600W TRUE rms. In reality if I get that JBL or the Audiobahn it will NEVER EVER be run that high, without clipping or blowing the subs.
Post Number: 128
Jimbo, what kind of amp are you running?
Username: Invain
Post Number: 1351
1600 true rms would be 130 amps. His stock alt. probably isn't even 100.
Post Number: 136
Ok then what about the Audiobahn A8000T? It's rms is 400. Is there any reason I can't run one of those? With my subs wired in parallel to it?
Post Number: 137
My dilema is that I really am not wanting to mess too much with any of the major mechanics in the car. I wouldn't have the money to have it fixed if something went wrong with a new alt.
