Simple Question
Quite
So im saving up for a RE X.X.X sub and an amp, im going to be putting them in a Ford Ranger extended cab. My question is what amp whould I get to run this sub? Ive been looking at JBL amps but there crazy expensive especialy the one ill need what do you guys suggest? and how do you think it will sound in the truck.
Oh ya also what type of box should I get I like the low deep bass and im not sure if sealed or ported would give me what.
Username: Hdubb
Farmington, Nm Usa
Post Number: 1004
if you are on a budget then look hifonics brutus bx1000 or 1500. or and older jbl bp1200.1
as for deep low bass a ported box tuned around 25 hertz would be awesome, but i think that space might be the limit.
Quite
Thanks, ya thats why I was leaning towards a sealed box since they take up less space and I might not even be able to fit a ported box.
Quite
Anyone have any other suggestions on an amp? I want to get a few oppinions.
Username: Taylor17
Kopperl, Texas
Post Number: 814
For the price, Hifonic's 1500D is the best. Like Hunter said, also look at JBL's 1200
