Thoughts on the Clarion Pro Audio XW1500 subwoofer
Username: Dpxpro
I'm thinking of getting a Clarion XW1500 DVC subwoofer and i just want some info and reviews you guys might have for me.
Username: James1115
Wilton, Ct
Post Number: 1371
I have no expierience with this particular sub but I can tell you that Clarion Pro Audio is decent stuff. How much are you paying for it? what kind of car is it going in? and what kind of amp are you going to be running it with? also are you into SQ,SPL, or SQL?
Username: Dpxpro
Im payin $250 Australian for the sub and im running off a 1000watt rms clarion mono digital amplifier. I havent heard of SQ, SPL and SQL what are they and ill check them out.
Username: James1115
Wilton, Ct
Post Number: 1435
SQ is how good it sounds sound Quality, SPL is how loud it will get Sound pressure levels and SQL is a mix of both
Username: Dpxpro
I havent got it yet im just gettin some stats on it before I go buying it. So you reckon Pro Audio goes alright then.
