Went to Audio Store (about 2 12" JL w7's)
Username: Shekei
Basically, I went to a audio store selling JL Audio W7's with the custom box made for it from JL audio itself. And he was telling me I don't need 2 12" because 1 is very good and was saying I would pretty much need to power with a JL 1000/1 and prolly another amp to. So he's pretty much wanting me to get just 1, I want to know which amps could run 2 12" JL w7s and make it sound nice, I don't wanna under power it.
Also, I already have 2 12" JL w3's but Im gettin a new car and giving those subs to my bro who split it with me. I wanna know if it will be louder (My 1 w7) with a new amp, vs my bros 2 12's w3's in a custom box with the Memphis 500RMS amp.
Thanks
Username: Subfanatic
Walton, Ky
Post Number: 588
id say that the 1 w7 will do the trick...i dont know about amp for them...i dont know anything about jl's for some reason
Username: Taylor17
Kopperl, Texas
Post Number: 743
It will probly be louder. The 1000/1 will power 1 w7 perfect.
If you want a crap load of bass, get 2, and another 1000/1.
2 will also cost a crap load more as well!:-)
Walton, Ky
Post Number: 589
haha yea...and if you do that...dont forget a new alt and a tons of sound deadener...but wow..that would be awesome...2 13w7s and 2 1000/1's...talk about weak ahha
Username: Shekei
lol. ok maybe just 1 w7, but will it beat my old system in BASS? if I got a 500/1 (or) a 10001/1 and a 13w7? or would a 12w7 be better?
Thx
Username: Sploosh56
Ohio
Post Number: 541
In my opinion it will beat it in both output and sound quality
Username: Taylor17
Kopperl, Texas
Post Number: 750
It should beat it.
Username: Invain
Michigan United States
Post Number: 1070
Don't really know what your local guy was thinking, but a 1000/1 is gonna be perfect for the w7. Your not gonna need another amp on top of that.
Walton, Ky
Post Number: 615
wait...the local guy said you would need more than that for a jlw7
Username: Invain
Post Number: 1072
"1 is very good and was saying I would pretty much need to power with a JL 1000/1 and prolly another amp to."
Username: Taylor17
Kopperl, Texas
Post Number: 769
If that's what he ment, what a moron!
What store was this?
Username: Shekei
He didnt mean that, he meant i would need more then a 1001/1 for 2 JL w7's.
Walton, Ky
Post Number: 622
well you wouldnt "need" it...but it would be awesome if you did it
Username: Nnnnick_b
Nc Usa
Post Number: 169
a 13w7 will be a good deal louder then a 12w7. The 13 has more surface area and greater excursion capabilities then the 12w7. A 1000/1 would be a great match for either sub. On the other hand, 2 12w7 would produce more spl then a single 13w7, but you would need to purchase a second 1000/1.
Username: James1115
Wilton, Ct
Post Number: 1340
well this is the way you break it down. Normally when you add another sub with the same specs and double the power you gain 3db's. If you had 1-12w7 with 1000 watts or 2-12's with 500 watts each they are going to sound the same. it is not worth the extra money if you are not going to power them both with the same size amp which would be a 1000/1 to each. 1w7 will be louder then 2-12w3's but personally I dont really like the SQ of the w7. My buddy just fried his 3rd w7 today. Its ok though his dad owns the store that sells it. the lucky ba$tard. But back on track I would run 2 jl 12w6v2's off of that 1000/1 it will be louder then the w7 and it will sound much better.
Username: Invain
Post Number: 1076
His 3rd? What the heck is he doing?
Username: Shekei
Thanks James and Nick and Sub, and everyone else who answered. Actually I can set up an appointment with the Audio store and what there gonna do is put in the amp/sub to let me hear it so that should be cool.
I wanna try the jl 12w6v2's now that u said that. Isn't w6 750 Watts piece?
How much watts for W6 12, vs W7 12. Thanks
Username: Shekei
Sorry I meant 300
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 85
w6 is different than w6v2...
w6v2 12 is 400 watts RMS and 12w7 is 750 watts RMS
a 500/1 is a great amp for the 12w6v2 tho
as well as a 1000/1 for 2 of them
Walton, Ky
Post Number: 639
the 2 w6v2 should have a much better sq..they sound amazing..and the w7's hit really hard...i just dont like there sq much
Post Number: 86
hey just curious what do you guys think would be louder/sound better(should sound bout just as good) 4 12w6v2s or 3 13w6v2s .. with a 500/1 to each sub
Username: Invain
Post Number: 1080
The 3 13's would be louder.
Post Number: 87
one more question then joe... 3 13w6v2s ... or 2 13w7s ... w6v2s have a 500/1 each... w7s have a 1000/1 each...
would it still be the w7s because of the xmaax and 500 watt increase?
Walton, Ky
Post Number: 642
yea it would be
Username: Invain
Post Number: 1082
That one would be hard to tell. Just because there's a 500 watt increase doesn't meen it's gonna be a ton louder, though it will make a difference of course. Doubling the power in general gains you 3 db's I do believe. And then there is the added xmax of the w7's. On the other hand, 3 13's are gonna displace a lot more air than 2 13's. I'm not sure on this one.
Username: James1115
Wilton, Ct
Post Number: 1343
400 but the 500/1 is a great match for it. the 1000/1 would be a great match for two of them. It will outperform your brother and be louder then 1 12w7 its the best of both worlds.
Username: Shekei
Post Number: 7
So james get the 2 w6 with 1000/1?? u mean?
