Which to get??
Username: Rob932
Post Number: 11
i have noticed that alot of people on here are only getting one 15" x.xx or brahma or avalanche or eclipse ti. i was just wondering how much better 2 avalanches (only sub i can afford 2 of but still a little more than i would like to spend) would be then one of any of the other and if its worth the money??
Username: Nnnnick_b
Nc Usa
Post Number: 165
the 15 in avalanche exibits 27mm of one way excursion. the brahma 15 does 29 and the XX.X does 32. So a pair of avalanches would be rather loud, and sound good(as far as i have heard acendant makes some pretty good sounding drivers)
Username: Rob932
Post Number: 12
so would it be worth the money to buy 2 avalanches instead of one. or would one x.xx or eclipse ti sound close to the same
Username: Nnnnick_b
Nc Usa
Post Number: 167
2 avalanches would easily beat a single xx.x. in spl.
Username: Taylor17
Kopperl, Texas
Post Number: 737
Ya, 2 will almost all way's be louder do to more surface areia.
Username: Rob932
Post Number: 14
sorry to keep asking but i plan on buying whatever i decide on this week and i have never heard any of these subs and i wanna make sure i get the most for my money. But one last question i know you kind of already answered it but i can afford 2 avalanches but its a little more than i would like to spend so would it be a big difference and worth the money to get 2 instead of 1???
Username: Rob932
Post Number: 15
any ideas???
Username: Subfanatic
Walton, Ky
Post Number: 605
how would the 2 avalanches stack up against 1 5 inch ti?....but how much are the 15 inch avalanches
Username: Rob932
Post Number: 17
i dont know how they compare thats what im tryin to find out myself but the avalanches are $299 each
Walton, Ky
Post Number: 609
wow thats a good price...i got my Ti for 350..maybe i should have looked at those
Username: Taylor17
Kopperl, Texas
Post Number: 759
Not for sure, think someone told me it's like a 5 db increase.
It just depend's on if you really want the extra 5 db's or not.
Username: Rob932
Post Number: 18
so would one avalanche have still be alot louder with higher spl then 2 15" L5's
Username: Taylor17
Kopperl, Texas
Post Number: 763
It will have better sq, close one on the spl though... hard choice. James is the expert on thee's sub's.:-)
Username: Rob932
Post Number: 20
wut sub/s would you recomend that will hit hard as hell for about $600 or less
Username: Taylor17
Kopperl, Texas
Post Number: 772
Just spl?
Walton, Ky
Post Number: 621
an eclipse ti 15,,, x.x.x 15, 12 w7, ummm there are more
Username: Nnnnick_b
Nc Usa
Post Number: 168
18" triple x would be pretty loud.
Walton, Ky
Post Number: 624
hhaa....yea it would....spend another 2 hundered and for 800 get a eclipse ti pro
Username: Rob932
Post Number: 21
how much are those?
Walton, Ky
Post Number: 626
usually around 900...but you can find them at certain places for 7 or 8 hundred....usually some interenet companies..if you email them alot...they will knock down the price...sometimes...my friend was getting a w7 and got a hundered bucks off cause he asked if they would take it off if he ordered the amp and wireing ther too
Username: Rob932
Post Number: 24
o well thats too much for me
Username: Hdubb
Farmington, Nm Usa
Post Number: 940
how much are you looking to spend? the aveys are 300 for the 15s the brahms and X.xx are a lot more, i think that the 18 aves are like 359 or something, which is a great price for a high quality 18. see the problem with a spending limit isnt the subs its the amps. amp to run these are exspensive
Username: Rob932
Post Number: 25
i already have a older precision power pcx 1500 that i had powering my 15" L5's so i just wanted to uprade my subs i don't really care about SQ i just want hella loud subs that i can feel in my chest if you get what i mean. that will work w/ the amp i already got
Username: Rob932
Post Number: 26
im lookin to spen about $500 i can go a little more if its worth it
Username: Hdubb
Farmington, Nm Usa
Post Number: 943
mmm just for the sub? nice amp. 18 xx.x or 9917
Username: Invain
Michigan United States
Post Number: 1084
If your going for the loudest you can get, look into the dd's. They've set a lot of spl records. Can't think of many single drivers that would get louder than a DD 9917.
Username: Rob932
Post Number: 27
how much is the x.xx and call me stupid but who makes 9917, mtx maybe
Walton, Ky
Post Number: 645
digital designs i think
Username: Invain
Post Number: 1097
DD = Digital Designs.
Username: Rob932
Post Number: 28
i dont think my amp will power either sub
Username: Hdubb
Farmington, Nm Usa
Post Number: 955
whats the wattage on it? i assumed it was 1500 watts
Username: Rob932
Post Number: 29
1500 yes
Username: Hdubb
Farmington, Nm Usa
Post Number: 962
the x.xx will take it, i cant remember the rms on the dd but im sure it will handle it then some. well maybe, is this going to be a daily driver setup? i would go with the x.xx18 if you could.
Username: Rob932
Post Number: 30
yeah this is my daily driver setup. So you think my amp will push that x.xx 18? and how much is it?
Username: Hdubb
Farmington, Nm Usa
Post Number: 966
yes it will. i dont remember the price but the 12 is 405 so i think that the 15 would be about 460 so the 18 is right around 500 if not a lil more
Username: Rob932
Post Number: 32
i dont know much about 18" subs but it will still hit hard and sound decent when im listen to music right(that might sound really dumb but i don't know anything about 18" or if their any dif than 15")
Username: James1115
Wilton, Ct
Post Number: 1351
hey Robbie if you want knock your damn hair off your head bass that will still punch you in the chest look into the Avalanche 18. It will give you the same output as 2-avalanche 15's. god knows why you would need that but it will do it.
Username: Rob932
Post Number: 33
i read that it rms is 800 watts would my pcx 1500 be too much
Username: Invain
Post Number: 1110
Get 2. :-)
Username: James1115
Wilton, Ct
Post Number: 1355
nope I was tlaking to a guy who was pushing 1400 to it with no problems at all. The only thing is it requires a large enclosure. Talk to chad he will help you out. Ask him about the Snail Shell enclosures he is going to be building soon. 1-avalanche 15 in a snail shell would be insane in the membrane! :-)
Username: Invain
Post Number: 1113
Hmm, how much is he gonna charge for that? I really don't feel like building a box.
Username: James1115
Wilton, Ct
Post Number: 1357
he told me $250-$300 which is about $100 cheaper then powerd 4 sound and he said it will come with a Black satin finish looking like a million bucks. I cant wait to get one.
Username: Rob932
Post Number: 34
i have a 01 monte carlo ss so i have plenty of trunk space thanks for your help ill give him a call tom.
Username: James1115
Wilton, Ct
Post Number: 1359
cool tell him you are interested in the box he talked to James about he will know what you are talking about.
