Putting a system in a leased benz
Username: Submarine16
Im new here and I know nothing about systems first off but:
im thinking of adding 2 subs (probably kicker or something good) along with an amp, obviosuly.
However, since the car is leased, if i install the subs and take them out at the end of 3 yrs without and problems like loose wires, holes, etc.
I listen to mostly rap and i just want a basic system. The car is small so i dont need anything big just something to make it bump
help with be appreiated
Username: Subfanatic
Walton, Ky
Post Number: 594
what is your budget
i dont know really like 500 for the equipment
and i dont want to a buy a new alternator or anytnig
Walton, Ky
Post Number: 595
well...for 500...ill sell you an eclipse al 10 inch 88100 model and a interfire audio IB2900C amp for 425 shipped if your interested....also...maybe just look around at some sites like...woofersetc.com and well help you pick some stuff out if your not interested lol
is that stuff in a encloser?
Walton, Ky
Post Number: 598
yea...its really crappy box that i built...if you give me 500 ill get you a really nice box to go along with it and ship it to you....but the box i have it in right now is pretty poopy....i am not too good with a jigsaw lol
Walton, Ky
Post Number: 599
or for 500 ill sell you 2 RF's stage 3's 12's...not in boxes sorry lol...with a power acoustic amp...way to powerful for these subs but can be turned down so it wont hurt them....for 500 shipped...up to you
Username: Taylor17
Kopperl, Texas
Post Number: 753
lol
Is that 500 for sub's/amp?
How minny sub's are you wanting. Also what size do you prefer?
Walton, Ky
Post Number: 600
yea its for both taylor...he wants to spend 500 for everything
Post Number: 7
and i dont even know where to start about picking out a system.
I have a fair amount of trunk space, but than again dont want to go fancy and have to replace my alternator. just somehting to make it crisp and bump thats a decent price.
Walton, Ky
Post Number: 601
well...hmm...with that stuff you wont need anew alt....or holes or anything..and wires are easy enough to take out...but first off...i would prolly pick out the sub(s) you want and what kind of power you want...do you want sound quality or sound pressure level...and then go find an amp...its going to be hard to find somen real nice for 500
Post Number: 8
my friend just bought 2 JL 12's and there redicoulsy loud that he hasnt even put them up to full blast, i can hear him down the block
i dont want anything liek that..
what about 2 10's? or even like 1 12?
Walton, Ky
Post Number: 607
do you wnat somen that sounds really good...orsomen that hits hard.,....or like in between
Username: Taylor17
Kopperl, Texas
Post Number: 758
The type R's from Alpine are grate sub's. The new one's are a little more, not for sure the price.
I know at www.sonicelectronix.com they are pretty cheep. Like $120/140 a piece.
Then you would need to find an amp that pushes 600/800 watt's.
Walton, Ky
Post Number: 608
taylor...what do you think about the 10 inch eclipse 88100 and the interfire amp lol
Post Number: 9
id rather have it loud
Username: Taylor17
Kopperl, Texas
Post Number: 762
Loud, the Eclipse should get pretty loud. Don't know anything about the Interfire amp, but wouldn't be bad if it is all in working condition. Also, you can find 12 Jlw3's for $180 a piece. They will git loud, and sound good at the same time.
Walton, Ky
Post Number: 613
yea...hoenstly..the amp is the best amp ive ever owned/seen in my own eyes...ive had power a jl12w7 with ease even though its rated at 550 rms..it def underrated...great great amp..and everyhting works great and sounds amaaznig and is really loud...if you wanna buy it
Post Number: 10
http://www.sonicelectronix.com/item_2457.html
what aobut soemthing liek that
it has everything i need and in a box and has an amp and is under my budget
i dont know how loud this is or how good though...
Username: Invain
Michigan United States
Post Number: 1071
Awwwe jeese, do not buy that.
Walton, Ky
Post Number: 614
haha...audiobahn isnt that good...and for 2 subs and amp it says 200 watts TOTAL RMS POWER...thats both subs combined..prolly will barely hear it...and will sound bad...look around some more....lol/....looks tight though
Username: Taylor17
Kopperl, Texas
Post Number: 774
That's not enough power.
Walton, Ky
Post Number: 623
joe and taylor...do you think he should buy one of my deals lol
Username: Rob315
Cuse, NY U.S.
Post Number: 231
i have 2 12" type r's in a box for $250 shipped..and i also have a few amps id sell ya for cheap if ya bought the subs.
Username: Invain
Post Number: 1108
Rob what amps do you got?
