Jbl GTO 1201.1 vs MTX 801D
cometgoal53
which will put out the best power, clarity and quality for 2 12" kicker l5s (jbl GTO 1201.1 or MTX 801D)?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 390
The GTO1200.1 will be a more powerful amp. the GTO will produce ~1200wrms at 2ohms. The 801D will produce roughly 800wrms at 2ohms.
Personally i would get the GTO1201.1 for 2 12" L5s...just make sure you get the DVC 2ohm versions if you go w/ the GTO1201.1 and wire them in series-parrallel.
cometgoal53
Thats what i was thinkin of doing, but then my friend tried to tell me JBL was crap, but i always liked their stuff.
Username: Taylor17
Kopperl, Texas
Post Number: 731
Mtx is better, but JBL isn't crap by any mean's. I would go with the JBL, more power to the sub's, and not from a crappy amp.
They should git pretty loud.
