NEED HELP!!!!!!!!!!!!!!
I plan on buying a silverado 2500HD will i be able to fit 2 12'sW6v2?
Username: James1115
Wilton, Ct
Post Number: 1272
single cab? I am assuming it is. That all depends. first you need to find what size boy you are able to fit, then find the cu/ft per chamber that the box is, then find a sub to match it. AAs long as you can have the proper depth I dont see why not. Those subs work great in 1-1.25cu/ft so its not alot of space. Look into boxes that will fit first.
Username: Taylor17
Kopperl, Texas
Post Number: 656
And if it is extend cab, your best bet will be a downfiring box.
Its a crew cab if that helps.
Username: James1115
Wilton, Ct
Post Number: 1278
you have plenty of room.....plenty!
Username: James1115
Wilton, Ct
Post Number: 1279
you have plenty of room. Go to subzone and see if you can fit their 1.25 sealed enclosure. it sounds great with that sub I have one myself.
10 INCH KENWOOD DB HAVE MORE BASS IN A BAZOOKA TUBE OR TO HAVE 2 10 INCH IN TRUCK BOX I HAVE RF AMP 600 RMS TO 1800 RMS
