Sub ohm's?
Username: Dsgbthuglife
how many 4ohm subs would it take for them to handle a 1ohm load?thanks..
Username: Gavbo211
US
Post Number: 20
3 subs. each time u divide by two so 2 4ohm subs would run at 2 ohms, and 3 4ohm subs would run at 1 ohm.
is there a diffrence in 1.33ohm and 1ohm?or is that still a 1ohm load?thanks..
Username: Bdonkersgoed
Ontario Canada
Post Number: 125
Keep in mind whether your subs are single or dual voice coil . . . this makes a big difference!
Regards,
Bryan
Post Number: 9
they are single voice coil subs..
Post Number: 10
i seen that 3 subs make 1.33ohm and 4 make 1ohm but if i use 3 for the 1.33ohms would i loose power from the 1 ohm load from the amp?
Username: Taylor17
Kopperl, Texas
Post Number: 678
It will heart just a little, but not enough to really notice.
