Blown Amp ?
Username: Grtnate23
After playing my system too loud, my auto-protect feature on my amp initiated. Ever since then I am not able to turn up the subs very much before the auto-protect turns on again. The fact that everything works lessens my worries, but I am not sure what might have happened. If anyone has any ideas, please share. Just ask for more details if you need them. Thanks.
Username: Carguy
Post Number: 1612
Check your gain/level setting on the amp. If it is set too high, it'll shut down. If you operate the amp with incorrect gain/level setting, it will eventually break down.
Username: Grtnate23
Yes, gain was too high. Is the damage fixable ? If so, approximately how much will it cost to fix ? Any other options ?
Username: Hdubb
Farmington, Nm Usa
Post Number: 909
cia engineering, i was told around 55 bucks +shipping to get it back to you.
Username: Carguy
Post Number: 1620
CIA? Are they related to FBI? Just kidding.
Before you repair anything, make sure your amp is worth 2x the repair cost, or else it's not worth fixing.
Lower the gain/level setting and see if it still shuts down. If so, then it'll need fixing/replacing.
