Do u have to break in subs?
Username: Ringmaster07
Post Number: 7
do u have to break in the subs when u first get them and if u do how long does it take for them to get broke into ive had my subs for 4 days now and ive been playing it on vol6-7 every night for like 4hours is it broke into yet u think it sorta feels like it is enlighten me plz?
Username: Invain
Michigan United States
Post Number: 795
I would still take it careful for a while. You can probably start gradually turning the volume up. The point of breaking your subs in is to loosen things up and to make sure the sub is working good and everything. You don't want to newly install everything and then go out and burp it.
Username: Invain
Post Number: 796
Username: Invain
Post Number: 798
But yes, you did the right thing. From what you said you've run it low for about 16 hours. That's a good amount of time.
Post Number: 8
sweet thanks
