PLease HELP, SUB problem
I have an RE x.x.x 15" sub. its about 1 month old . about 1 week ago it started making this weird noise when i bump it loud. like distortion or something, its like a... I cant explain, the point is that its making a really annoying and disturbing noise that it was not making before.Im feeding it 1200w RMS x 1 @ 2 ohms , the sub is a dual 4 ohm. once in a while i may bump it and it just to get loud and produce clean deep bass. the sub is rated @ 1600 w RMS. should I send it back. I beleive RE's have 3 year warrantys. thanks every 1
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 313
see if it the amp first. try another speaker.
anymore suggestions ?, I'm checking the amp with another sub too by the way, I don't beleive is the amp though, its about 2 months old. Its an Infinty 1210a mono class D amp. has anyone else had a problem like this before? thanks every1
Username: Symplestiles
Stockton, CA Usa
Post Number: 314
check your gains, if they are set too high it could be damaging the sub
