Eclipse titanium 12"
Username: Jmloughrey
Farmington, CT
Post Number: 942
I was thinking of using an MTX801D to power this sub, would this be enough power? The subs rated 750rms...
Username: Taylor17
Kopperl, Texas
Post Number: 485
I would think so, I've heard they can handle more than they are rated.
Farmington, CT
Post Number: 944
i know they can handle more then they are rated, my bank account cant though...
Username: Erik123456
Arlington, Tx
Post Number: 398
jeff - do you already have a ti?
you know they are dual 4 ohm right
Arlington, Tx
Post Number: 399
Farmington, CT
Post Number: 946
nope, i have nothing, i am still in the proces of desiding what i want, i did know it is a dual 4 ohm sub though
Arlington, Tx
Post Number: 400
mtx 801d @ 4ohm is like 400 watts i think
Username: James1115
Wilton, Ct
Post Number: 762
I believe its 750 4ohms and 1500 2 ohms
Arlington, Tx
Post Number: 401
Dynamic Power 14.4 VDC
2 Ohm Load 800 w x 1
4 Ohm Load 400 w x 1
Arlington, Tx
Post Number: 402
i only know bc i was looking at amps for the same sub and i wanted mtx but they didnt really have one that fit well
Username: James1115
Wilton, Ct
Post Number: 764
yup my bad I was thinking of the 1501 its been a long day.
The mtx amps are underrated and that 801D would putting out more than 800 wrms at 2 ohm,
IMO, this amp is a good match for that sub if your not willing to pay the extra bucks for a good 1000 watt class d amp.
Farmington, CT
Post Number: 952
its not that i'm not willing, its that i dont have that kind of money to spend on a system, i have other bills and whatnot i have to pay...
Username: Hdubb
Farmington, Nm Usa
Post Number: 725
i thought you were getting some atlas'?
Farmington, CT
Post Number: 953
i dont know what the hell i'm doing, yo hunter, you still want that kenwood amp? i'll throw it to ya super cheap
Arlington, Tx
Post Number: 421
800 watts at 2 ohm is still no good, maybe im wrong but im pretty sure you have to run it at 4 ohm
jus get the dual 4 oh ti and wire it down to 2 ohms for d 801
good amp, good sub, good price and it wouldnt kill ur wallet.
Username: Hdubb
Farmington, Nm Usa
Post Number: 747
ya. give me some time. my year and a half anniversery is hitting me hard, but ill throw you an email, did you find what you needed for you bike? ill email you
Farmington, CT
Post Number: 954
yup, bike will be operational in the next 3 days, waiting on the last of the parts to arrive for installation, i'm so ready for it to be nice outside again
Username: Hdubb
Farmington, Nm Usa
Post Number: 749
ya me too. i have a lot i need to do to my system, but it has been raining crazy here. i need to build a new box, i need to build some custom pieces so i can fit 6.5s in my front doors, instead of 4x6s need to install my 225 hcca. what did you end up getting?
