I need a 1000w amp<<<
i need a 1000w amp for my 2 12's, anyone wanna sell or got suggestions?
Username: James1115
Wilton, Ct
Post Number: 727
what kind of 12's?
dual, nothin special im not lookin to blow anyone away, just sound good
Username: James1115
Wilton, Ct
Post Number: 766
I would not put a 1000 watts to those subs if I were you. I would try something like 250/sub
Username: Perrydog
Flint, Michigan USA
Post Number: 66
ya i was gonna buy sum duals then i checked in to the specs on them and asked around so far i havnt found out that dual have a good rep, iv heard ya they sound good for about 3 mnths then blow or fry or just stop pounding,deff dont throw 500 to each sub
I agree, i don't think you need to put 1000 watts to your subs, but if you are looking a clear powerful sound, you might want to consider the JL 500/1. I had this amp when i had two 12s and it was more than enough power then i needed. The rms is 500, but that is under rated, its more like 700-800.
