How do you guys think this will sound?
Username: Loudon
Post Number: 110
Subs - 3 JL W3v2
Amp - JL 500/1
Slot Ported Box
It will be in a zx3 ford focus
Username: James1115
Wilton, Ct
Post Number: 655
good
not enough power
Username: A3forme
Post Number: 328
Definately have to agree w/ Anon. Serious under-powering going on.
Username: Taylor17
Kopperl, Texas
Post Number: 453
Could use a little more power, but it should sound good.
Username: Loudon
Post Number: 111
yea i was thinking that .. what amp would work well with this setup? any ideas? suggestions?
Username: Loudon
Post Number: 112
what about the mtx 1501d?
Username: Taylor17
Kopperl, Texas
Post Number: 454
Maby the 1000/1
Username: Loudon
Post Number: 113
1000/1 is wayyy to expensive overpriced in my opinion
Username: Loudon
Post Number: 114
what if i went with 2 w3v2s? the 500/1 would push those very nicely wouldnt it?
Username: James1115
Wilton, Ct
Post Number: 658
yeah it will slam 2 of them nicely but it will also power 3 of them as well. The 1000/1 would be over kill too much power. I ran 3 10w6's that are 3oo rms with 600 watts and they slammed very very nicely so I wouldnt say that they would be underpowered. plus that amp itself is underrated as well.
Username: Loudon
Post Number: 115
so james u have ne suggestions as to an amp to power 3 of em ? what do u think will power them optimaly without having to pay 600 dollars for a 1000/1
p.s i live in norwalk ct
Username: James1115
Wilton, Ct
Post Number: 672
Nice man right around the corner. Hey Mike are those w3's dual 2,4, or 6 ohm subs?
Username: Loudon
Post Number: 116
I didnt get em yet I am going to buy them I wasnt sure which ones would be better to power? 2 or 4 ohm?
Username: James1115
Wilton, Ct
Post Number: 673
Hey Mike I think I got a combo that would work really well for you. Get the dual 6ohms run them at 1ohm mono to a orion Hcca 250G4 or GS or the competition amp but try to locate a G4 or Gs first it will power those subs beautifully. As a matter of fact I would really want to hear that.
Username: Loudon
Post Number: 117
James thats way to much money for me I can spend 600 on an amp .. although that is a good amp ... i cant do it .. i dont have the funds ... my dad has the 250g4 in his cadillac ... nice amp for sure
but couldnt like the kicker kx1200.1, mtx 1501d, those amps push 3 very nicely?
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 284
The MTX is only two ohm stable. Can you wire 3 speakers down to two ohm?
Username: Loudon
Post Number: 119
i think im gonna go with 2 w3s but what ohms should I get the subs in 2,4,6?
Username: James1115
Wilton, Ct
Post Number: 710
Ok Mike I just got a 250GS which is the same as the G4just all red for $300. Look on Ebay you can find them on there sometimes. I mean you dont have to get that amp but I would. If you want to run three of those I would deff get dual 6ohm that way you can run them easily at 4ohms or 1ohm. As for amps there are many many amps that will suit your needs. The kicker will be too much power for those and neither of them are stable at 1 ohm and dont put out enough power at 4.
Ok forget what I just said I didnt see that you are going with only two of them now my bad. lol!
I would get dual 2ohm run them at 2ohms with a JBL 600.1 or a Kicker 600.1 they will sound nice.
Username: Loudon
Post Number: 120
James ive come to the final conclusion
but i need your help as to what ohm subs i could should get but im defintely getting the w3v2s and a jl 500/1 but what ohs subs dual 2 or 4
Username: James1115
Wilton, Ct
Post Number: 718
dual 2. http://jlaudio.com/tutorials/wiring/index.html#2dvcsp
Username: Loudon
Post Number: 122
so the dual two ohm subs will give me the maximum wattage outof the amp to the subs correct cuz itlll b a 1 ohm load?
Username: James1115
Wilton, Ct
Post Number: 725
no a 2 ohm load run them in Series / Parallel.
Username: Loudon
Post Number: 123
how do u think this will sound james in a focus hatch... im guessing pretty loud and clean
Username: James1115
Wilton, Ct
Post Number: 772
yeah man it will sound nice!
