Door speakers and amplifier..
Username: Jbz
Tennessee USA
Post Number: 10
I need some opinions on the speakers I am looking at and the head unit that I have and the amp to go alone with the speakers:
Head unit - Kenwood Excelon KDC-X679
Speakers - Four Pioneer Premier 6.5" TS-A640P
Amp - Kenwood Excelon KAC-X521
What do you think? Thanks in advance for your help.
Username: Kklagge
Post Number: 72
What kind of car/truck? I'd go with 2 speakers up front and a sub in the rear, personally.
Username: Jbz
Tennessee USA
Post Number: 12
I have an '02 Nissan Pathfinder. I already have two 12" subs in the back..
Username: Kklagge
Post Number: 74
If you have (2) 12's in the back then forget the rear speakers because you won't hear them anyway...save the money and put something better in the doors. You have quite a bit of mounting depth in the doors so you can pretty much put any 6-3/4" comps you want in there. I have CDT CL-62's and couldn't be happier (they handle 150+ RMS)
Username: Jbz
Tennessee USA
Post Number: 16
Do you think that 6.5" Pioneer Premier speakers would be decent enough?
