How about the JL 15W3v2 subwoofers?
Username: Suleman36
Post Number: 24
I havent heard to much noise about these on the threads> Im very curious of how they whould sound. It says they are 500rms and i have jl 500/1 amps. Does anyone know anything about this sub and how it whould sound?
i have 3 jl 10w6's and they bang like a mofo they are sick as hell
Username: James1115
Wilton, Ct
Post Number: 670
it is a nice sub. Hey Legions are they the old w6's? I have the wedge box with 3-10's also and yes they do slam.
Username: Suleman36
Post Number: 26
Hey james or anyoen else..So its a nice sub? How whould it compare to like the w6v2 that i own. any other info on the 15w3v2
Username: James1115
Wilton, Ct
Post Number: 676
it will put out a different sound more towards SPL and less SQ then the w6v2. it all depends on what you are loking for. As for power equirements one of your JL 500/1's will be optimal for it. I think you said you listen to alot of rap. It will get very low in a 3-4cu/ft ported enclosure with 500 watts.
LegiontDOTcom
hey james, yea they are the older ones.. the ones that have the white jl on the front... im actually trying to sell them.. i have them all in one box... and a 1200 watt xplod amp... anyone want it im looking to get $550... its like a $1100-$1200 setup
Username: James1115
Wilton, Ct
Post Number: 680
yeah I have the same ones just sitting in my garage now. I loved them they were so clean and loud.
