Zapco Symbilink???
Username: Ffxdevilarms
Post Number: 192
I just ordered the Zapco Reference 500.1 and do not understand Symblink. Do i need something special to use it and will it cost me a lot to use it?
Username: Invain
Michigan United States
Post Number: 537
Symbilink is your RCA cables pretty much. I believe you get a box and specail RCA cables. I think Symbilink uses really strong signal strenght and other stuff to get the best sound quality out of your stuff.
Username: Jonathan_f
GA USA
Post Number: 3207
Symbilink is a balanced DIN cable, designed to use a 16V balanced signal to drive the amplifier with. There are symbilink converters you can purchase, and you'll have to purchase the cables. It's basically just like firewire cable, but I think they use their own special DIN cable.
