Does any1 have a system in a cadillac escalade?
pietro
i cant find a wiring harness for a 2004 cadillac escalade i bought 1 wiring harness and it only let the right speakers play and i had 2 keep my stock deck in back. so if any1 has experiance with escaldes plz tell me where to get the proper wiring harness for one
Username: Avalanche
Post Number: 112
If you have the Bose stereo with the truck and you do not know what you are doing it will never work.
If you do know what you are doing the amplifier that comes with the stereo is located underneath you cup holders in the center console.
You will probably have to by pass the whole amp.
Good Luck.
I have Avalanche with the exact same issue. I laid down new wire all over the truck. That will be fun.
