Kicker Solobaric L7 or Rockford Fosgate T1??
hey evereyone
im looking for the best single 10'' sub i can get within the price range of a solobaric L7 or a T1. im not sure whats better tho. what would you guys recommend out of these 2 or would you recommend somethign completely different?
amplifier advice would be helpful as well.
thanks
im looking for as much bass as possible with decent SQ
i dont want distorted sound. i want deeep, clean bass
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 270
both are nice but also consider the mtx 9510.
Username: Invain
Michigan United States
Post Number: 494
Your definitely gonna wanna go with the Ti. Eclipse is very good, and that Ti will kill the L7 in sound quality, and will probably be just as loud. Eclipse's are very good quality, I know you'd love it.
Username: James1115
Wilton, Ct
Post Number: 616
I think he was refferig to the Fosgate T1 not the Eclipse TI. Who knows I cold be wrong. If you want to look in that price range look at The Atlas 10 or 12 by ascendant audio. Also look into the Adire shiva. ID max would be a hell of a way to go it would destroy the L7. Thats just a few I would recomend
Username: Invain
Post Number: 503
Yeah, I think your right James. My bad lol. At a glance the 1 looked like an I.
Username: James1115
Wilton, Ct
Post Number: 619
yeah I would have recomended the TI over the L7 any day and twice on sundays as well.
Username: Invain
Post Number: 508
Yeah, I'd recommend the Aluminums over the L7's as well.
Username: James1115
Wilton, Ct
Post Number: 621
absolutely!
