Whats the minimum amount of watts a brahma needs to reach full x-max??
its a 12" and Im going to only have around 800 -1k watts will it be enuff for full linear excursion?
Username: Invain
Michigan United States
Post Number: 498
I know it would work ok. I would try to go more twords the 1k end though. Your gonna want to get as much as you can outta that sub. I don't think it requires close to the max. rms to reach full excursion though. I hear of people running about 900 watts to it just fine.
Username: James1115
Wilton, Ct
Post Number: 618
you actually dont need anywhere near that amount of power to bring that sub to full excursion. Depending on the amount of space you have that sub will reach full excursion with 500 watts in a 2.10 cu/ft sealed box which isnt very big. Here check this out. http://www.adireaudio.com/Files/BrahmaPowerHandling.pdf hope it helps. If you are going to be running that kind of TRUE power then go with a very small sealed box.
Username: Invain
Post Number: 506
Yup, larger the box lower the power handeling. If your gonna go with a ported box, which will probably be pretty big, you'd really only need from 450 - 600 watts according to that sheet. Sounds kinda low, but hey if it's what Adire recommends...
