Adire and ascendant connection
jamivest
i,m running the ''famous'' jbl amp that i see talked about about so often in thi forum and i was wondering if anyone had any experience with the atlas or shiva subs. i noticed these subs have the same motor structure .xbl^2. any advice on which would probably be best
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 344
hi jamivest,
i just wanted to point out to ya that the adire shiva is not an XBL^2 sub. but the atlas is.
from what i hear, the atlas is a great sub. i havnt ever messed w/ the atlas personally though.
oh...and what model jbl do you run, from what you say about "famous" all i can gather is that you either have a bp600.1 or a bp1200.1. which is it?
i run a bp1200.1...its a great lil amp.
jamivest
the 600.1 is the one i have.i may have gotten my wires crossed when i was trying to look through both sites.thanks
