Looking for an amp
toyo
I need an amp to power my subs, here is what I am looking for. A small amp, dont need that big of an amp, 2 channel, can do 400-500 watts x2 @ 4 ohms, and cheap. Thanks
Username: Salvester
ProvidencialesTurks and Ca...
what do you think about audiofonics 1500w 2ch or kicker 850.2 which you think would give you a better response and what speaker would you subscribe for it
Username: Solacedagony
New Jersey US
Post Number: 273
I'm guessing you mean Hifonics. Either way, I'd recommend the Kicker amp.
toyo
alright, any more?
Username: Shouder
Wisconsin
Post Number: 113
what do you mean you don't need a big amp. 400-500 x2 @ 4ohms is a pretty big amp, and expensive. I don't know any cheap amps that have that much power.
